Komori LS-529+LX-HUV
Sheet Size: 53x75
thickness paper to 0,8 mm
5 Colors, Coating Tower, Extended Delivery
Impressions: 130 million
Year 2012
Equipped with:
. Console PQC-S Komori (Print Quality Control)
. PDC-S II (Print Density Control - Colour Management)
. KMS IV (Komori Monitoring System)
. KHS-AI (Advanced Interface)
. AMR (Automatic Make Ready)
. Full-APC (Automatic and semi-Auto Plate Mounting)
. Cocking Register (lateral, vertical & diagonal)
. Automatic Washers Devices: Rollers, Blanket & Impressions cylinders
. Pre-connected to CIP3
. Komorimatic Dampening
. Technotrans Alpha.c 120L Refrigeration System + Alcocontrol
. Feeder with Suction-belt feed table
. Double Sheet & Side lay Detector
. Ink Temperature Control
. Venturi Air Guide (Skeleton Transfer Cylinder)
. Chromed Impression Cylinders
. Extended Delivery
. Dryer H-UV Baldwin
. Baldwin H-UV water Cooler system
. Coating Tower Harris & Bruno with "Chambered Doctor Blade" and 2x Anilox Cylinders
. Air cabinet with the machine
. Automatic Washer LithoCoat for Chambered Doctor Blade
vipzak2@gmail.com
Sheet Size: 53x75
Year 2012
Equipped with:
. Extended Delivery
vipzak2@gmail.com
БР-110 запчасти с разбора (1)
X-RITE iCPlate2 X (1)
Perfecta 76 uc (13)
