Подбор, поставка и все сервисные работы для флексографических и офсетных машин Монтаж и демонтаж, пуско-наладочные работы любой сложности вышеперечисленного оборудования. Подбор и поиск как нового так и подержанного, бывшего в употреблении оборудования...
RMGT Ryobi 920 ST-4
Max Sheetsize 640mm x 920mm
Colours 4 Colours
Year 2023
Impressions 8 million
Smart FPC - Simultaneous plate changing
Smart Make Ready
PDS-E SpectroDrive
Wallscreen Display
PPC Server III
Ryobimatic-D
Ink Temperature Control
Auto Ink Roller Wash
Auto Blanket Wash
Auto Impression Cylinder Wash
Pneumatic Sidelays
Auto Pile Alignment
UV Prepared
Ink mist extraction
Grafix Dry Spray
GEW LED UV Drying - End of Press
(RMGT 920 ST-4 LED-UV, Ryobi 784 EP, Ryobi 925, RMGT 920 ST-5 CC with Lithoflash Inline Colour Control, RMGT 920 PF-8)
KBA Rapida RA105-6+L ALV2 CX
Year 2017
SAPC. Preset. Colortronic – Ergotronic ACR. Varidamp. Cleantronic Ink, Blanket and Impression Wash. Anilox Coating Unit. KBA IR/Air Dryer. ALV2 Extended Delivery. Dry Spray. CX Package to 1.2mm.
(KBA Rapida RA74-8 SW PHWA, Rapida 106-8 P SW4, Rapida 105-8+L SW ALV2 PWVA (UV),
Rapida 105-6+L ALV2 HYBRID, Rapida 105-4+L)
MAN Roland R705+LV Hi Print
Max Sheetsize 740mm x 1040mm
Colours 5 Colours
Year 2007
Impressions 75 million
Max stock thickness: 1mm
APL - Automatic Plate Loading
Auto Format Setting
RCI - Remote Control Inking
PECOM - Press Management System
ColorPilot - Densitometry And Colorimetry
MAN Roland Deltamatic Dampening
Technotrans Beta.c Combi Unit
Water Cooled
Auto Blanket Wash
Carton Guides
Double-Sized Impression Cylinders
Sheet De-Curler
Dedicated Coating Unit With Chambered Doctor Blade
Extended Delivery
IR dryer (Roland Seccomatic)
AirGlide Delivery
Grafix Dry Spray
(MAN Roland R904-7B, MAN Roland R706+LV HiPrint, MAN Roland R708 P Direct Drive)
HEIDELBERG CD 74-4C
Max. paper size: 530x740 mm
Speed: 15.000 sh/h
Weight approx.: 23090 kg
Colors: 4
Counter approx.: 100 mio
CP 2000 Center - High Pile Delivery - AUTOPLATE – PRESET Stream Feeder (Automatic size setting) - ALCOLOR Vario dampening - Technotrans central refrigeration with Alcosmart - All Automatic Washers – Weko Powder spray – antistatic device - Steel Plate in Feeder and delivery – air supply AirStar Pro - Air cooled
(Heidelberg Speedmaster CD 74-4P, Heidelberg Speedmaster SM 74-4, Heidelberg Speedmaster XL 75-4 (C) LE-UV, Heidelberg Speedmaster CD 102–4, Heidelberg Speedmaster CD 102–4+LX, Heidelberg Speedmaster SM 74-5, Heidelberg Speedmaster CD 74-5+LX (F) )
Omet
Model XFLEX 6
Year of production: 2010
Number of colors: 10
Automatic tension control relax-delam 2 colors.
Peel & read - removable rail mounting of the label-on-label flip device (
removable turning bars fixed on the rail , crosswise, marking on
the label (removable and readable - Peel & read)
Gearless, servo-driven control
Max / min material width : 430/150 mm
Print width: 410 mm
Print length repeat: 749.3 mm
Max. speed: 200 m / min automatic register
Winding type: Automatic preliminary longitudinal and transverse registration along
the winding axis without operator intervention and loss of material Unwinder type:
Automatic
Unwinding module with automatic tension control and with a built-in roller lifting system
Drying: GEW UV dryers
System closed-loop cooling
Printing material: standard self-adhesive labels and cardboard with a density of up to 250
g/m2.
Cleaning system: Autoclean
Video control system: yes
Automatic control of parameters stored in the machine's memory
Additional information:
The kit includes an electric cabinet equipped with 2 cutting cylinders and
roller carts, tools and materials for removing and removing
GOEBEL
Model: VSOP 520
Year: 2008
Number of colors: 8
Web width (mm): 520
Print width (mm): 510
Print repeat range (mm): 381 - 762
Drying: 7 UV dryers IST and hot air for the gravure unit
Unwinder: single
Rewinder: single
Additional Information:
- Kelva web cleaner
- In line gravure unit from DCM year 2012
- Max mechanical speed 365 m/min = 1200ft/min
- 7 colours with interchangeable system,
- OFFSET or FLEXO + 1 rotogravure unit inline coating
OMET
Model: Flexy 330
Year: 2008
Number of colors: 8
Web width (mm): 350
Print width (mm): 330
Drying: all stations with UV drying , N.3 stations with additional heated air driers
Unwinder: Single
Rewinder: Double
3 corona treater
UV lamps by GEW
1 turn bar
Material thickness min 50 micron max 350 micron
1 turn bar
Cold foil
lamination
2 die cut station
1 lamination unit for varnish and self adhesive lamination
Counter impression rollers double wall cooled
Included:
8 Anilox
Nr 8 plate cyl repeat Z96 + Magnetic cylinder Die Cut .
Nr 8 plate cyl repeat Z144 + Magnetic cylinder
Nr 8 plate cyl repeat Z74.
Nr 8 plate cyl repeat Z 82 .
Gallus EMS 340
Year 2009
Unwinding
Splice detection with acoustic warning signal
2x Corona infeed,
1x Arcotec web cleaning
8 flexographic printing units
3x screen printing units, interchangeable
2x rotary die-cutting units
Scribing tool with cross cutter
Rail system
1x additional winding/unwinding unit (laminate)
1 x additional cold foil embossing
Insertion offset station for the production of multi-layer labels (web offset device)
8x GEW UV dryers with cooling roller
Hyfra cooling machine
BST video control
Automatic register control Sensotec
Format length correction in the printing and processing area - Recommended for stretchable materials
Grid winder
Unwinding
Spreading roller and pressure arm for crease-free winding of thin foils and aluminum
(Gallus 2025)
Gallus RCS 330
Year 2011
1 Kocher & Beck unwinding machine
1 conditioning unit 1500mm
1 web cleaning
1 corona
7 printing platforms 1250mm
2 printing platforms 1000mm
9 active antistatic Eltex
Back printing for flexographic printing
3 flexographic printing units
1 screen printing units
7 offset printing units
9 UV drying units Uviterno
Automatic color zone adjustment BST
1 platform 1250 for punching machine
1 rotary punching units with GAP Master
1 back slot device
Rail system
1 back printing on glue
1 laminating device
1 cold foil device
1 extension laminating device for SK laminating
1 peel off device on rail
1 discharge unit 1250mm
1 grid winder
1 grid tear control
1 Kocher & Beck rewinding machine
Format cassettes:
5 x z166 / 12 x z176 / 12 x z 192
Flexographic printing cylinder
2 x z164 / 6 x z166 / 8 x z176 / 10 x z192
Magnetic punch cylinder
1 x z158 / 1 x z164 / 1 x z166 / 1 x z176 / 1 x z192
Gallus RCS 330
Year 2006
1 Martin unwinding machine
1 web cleaning
1 corona
9 printing platforms 1250mm
3 flexo printing units
2 screen printing units
Hot foil stamping
6 offset printing units
1 hot air drying
1 platform 1250 for die cutting
2 rotary die cutting units with GAP Master
1 longitudinal cutting unit
Automatic longitudinal and cross register control
100% control AVT
Rail system
1 backside printing on glue
Web turning device
1 laminating device
1 run-out unit 1250mm
1 grid winder
Grid break control
1 Martin rewinding machine
Format cassettes:
6 x z112 / 6 x z136 / 6 x z 150 / 5 x z158
Flexo printing cylinders:
6 x z96 / 6 x z112 / 10 x z136 / 8 x z150 / 6 x z158
Magnetic punching cylinder:
1 x z96 / 1 x z112 / 1 x z136 / 1 x z150 / 1 x z158
Omet iFlex 370
8 x flexo printing units
8 x GEW UV
1 x reversible cross beam
1 x Delam Relam
1 x cold foil unit
1 x Peal & Seal unit for multilayer labels
Printing width 370mm
no chiller
list of cylinders will follows
mechanical speed max 200 m/min
speed with die cutting max 160 m/min
machine manufacturing year 12.2016.
together with machine also a large set of die-cut metal sheets.
machine switched on max 300 days and operated max 150 days, 1 shift!!
Планетарная 6-красочная рулонная ротационная машина высокой печати трубного ламината
"Ko-Pack 250 Super Tube"
Основные технические характеристики:
Макс. ширина хода ленты: 10.63" (270 мм)
Макс. ширина ленты: 10.24" (260 мм)
Макс. область печати: 10.00" (255 мм)
Макс. толщина материала: 0.002"-0.014"
(0.05 мм-0.35 мм)
Макс. рабочая скорость: 330 ф. (100 м) в мин
Диаметр намотки/размотки: 31.5" (800 мм)
Втулка рулона (стандарт): 3.0" (76 мм) + адаптеры 6.0"
(152мм)
Печатные секции: 6 секций высокой печати +
1флексосекция
Привод: 1/8 C.P. (3,175мм)
Необходимое электропитание
(машина):
200/220 Вольт, (понижающий
трехфазный трансформатор
380/220 в наличии)
3 фазы, 50/60 Гц,
75 ампер
Необходимое
электропитание:
(УФ-система с воздушным
охлаждением)
200/220/480 Вольт,
3 фазы, 50/60 Гц.
Вес 1545 фунтов (3400кг)
Высота 90.55" (2300мм)
Длина 104.75" (2660мм)
Ширина 50.98" (1295мм)
Gallus Labelmaster 440
Year2021
Equipment
Substrates
Substrate thickness min.: 15 µm
Substrate thickness max.: 350 µm
PS Materials
Cardboard
Monofoil Label Materials
Special Substrates
Automation
Automated format length correction and snap-back compensation
Web-video System with manual side adjustment
Basic Equipment Register Control
Feeding Unit
Web Cleaning
Unwinding device: max. reel diameter 1000mm
Infeed device: Base module 1600mm
Printing
Flexo
Flexo Printing
Flexo Printing Units: 8x
Screen Printing
Screen Printing
Screen Printing Units: 1
Finishing
Rotary Die Cutter Units: 1
Cold Foil Printing Device
Drying
Water cooled
IR or UV: UV Dryer (hybrid lamp housing an LW2 LED cassette and an E2C arc lamp cassette can be used interchangeabley on the same print unit)
Web Storage
Max. Web Diameter: 1,050 mm
Outfeed Unit: Base module 1600mm
Rewinding Unit: up to a diameter of 1,050mm
Additional Equipment
Plate Mounting System: Heaford 700 FTS
Slitting System: Prati Saturn
Seaming Machine for Shrink Sleeve Labels: Brotech SM500 Seaming Machine
Sheeter: RBJ-460S Hig hSpeed Sheeter with unwinder and 1.2m conveyor
Washing Systems: Recyl Graphics Parts and Roller Washing machines (Simplex HP 80 (7 bar), NW2 Narrow-Web Anlox Cleaner)
Technical Details
Speed: 200 m/min.
Web Width: 220 - 445 mm
Max print size width: 440 mm
format length graduation: max. 635 mm
Китай, Индия:
Горизонтальные флексопечатные машины практически любой оснастки - до 12 цветов, UV сушки, секции цифровой печати, высечка, вырубка, длинная печать и т.д. Также всегда в наличии большой выбор дополнительного оборудования.
Вертикальные флексопечатные машины самых различных комплектаций с ценой. Машина разрабатывается индивидуально под каждого клиента, а благодаря готовым клише срок производства может быть не более 30 дней.
Запчасти
Подберём по Вашим параметрам интересующее оборудование и поможем продать Ваше!!!
vipzak2@gmail.com
