OMET
Model: Flexy 330
Year: 2008
Number of colors: 8
Web width (mm): 350
Print width (mm): 330
Drying: all stations with UV drying , N.3 stations with additional heated air driers
Unwinder: Single
Rewinder: Double
Additional Information:
3 corona treater
UV lamps by GEW
1 turn bar
Material thickness min 50 micron max 350 micron
1 turn bar
Cold foil
lamination
2 die cut station
1 lamination unit for varnish and self adhesive lamination
Counter impression rollers double wall cooled
Included:
8 Anilox
Nr 8 plate cyl repeat Z96 + Magnetic cylinder Die Cut .
Nr 8 plate cyl repeat Z144 + Magnetic cylinder
Nr 8 plate cyl repeat Z74.
Nr 8 plate cyl repeat Z 82 .
vipzak2@gmail.com
Model: Flexy 330
Year: 2008
Number of colors: 8
Web width (mm): 350
Unwinder: Single
Rewinder: Double
3 corona treater
UV lamps by GEW
1 turn bar
1 turn bar
Cold foil
lamination
2 die cut station
Included:
8 Anilox
vipzak2@gmail.com
Perfecta 76 uc (13)
