KOMORI Lithrone LS 640 C (X) LED UV
Max. paper size: 720x1030 mm
Smallest size: 360 x 520 mm
Image area: 710x1020 mm
Plate size: 800 x 1030 mm
Speed: 16.000 s/h
Stock thickness: 0.06 - 1.00 mm
Blanket size: 1040 x 920 mm
Colors: 6
Counter approx.: 123 mio
Model LS 640+CX Hybrid with LED UV <> Raised press <> Series 45 automation package – Skeleton transfer cylinders <> The press is equipped with LED UV <> There is one cassette that can be installed after unit 6 or after the coater. <> LED UV inks and LED UV coating simultaneously with the LED cassette installed after the coater on a daily basis. <> Single cassette after the coater will cure both the LED UV inks and LED UV coatings at the same time. <> Raised press with bandstand height catwalk platforms <> Komorimatic dampening system – with Delta-effect <> Full APC <> PQC off press controls <> PDC-SII for closed loop scanning <> KMS-IV <> IR dryer with hot air knives <> AMR for paper size and thickness presets <> Anti-static device <> Dedicated tower coater with extended delivery <> Anilox coating system with chambered doctor blade <> Air Motion Systems LED UV lamps in unit 6 <> Ink temperature control <> Pierry IR dryer with hot air knives <> Grafix Powder spray <> Solution R&R
vipzak2@gmail.com
Speed: 16.000 s/h
Colors: 6
vipzak2@gmail.com
№1 Как зайти на KРÁKÉH 2026: самый полный гайд с актуальными (0)
!6+ Как зайти на KРÁKÉH 2026: Полный список зеркал 1562 (0)
+21 Как зайти на KРÁKÉH 2026: Полный список зеркал 1345 (0)
+21 Как попасть на KРÁKÉH 2026: Полный список зеркал 2151 (0)
!21+ Как зайти на KРÁKÉH 2026: Полный список зеркал 1523 (0)
Актуальные ссылки на KРÁKÉH 2026: Полный список зеркал 1551 (0)
