2015 OMET X6 8 UNIT FLEXO AND OFFSET LABEL PRESS
Unwinder
1st print unit Flexo
7 offset print units
8th print unit Flexo
Rewinder
Max. speed (is dependent upon the printing size) 660 FPM - 200 m/min.
Max web width 530 mm (20" 7/8)
Flexo Printing repeat from 12" to 25"
Flexo Printing repeat (only reel to reel) from 304,8 to 635 mm"
Screen Printing repeat from 16" to 25" 2/8
Maximum flexo printing width 520 mm (20" 4/8)
Maximum screen printing width 520 mm (20" 4/8)
Maximum die cutting width 520 mm (20" 4/8)
Maximum die cutting repeat from 16" to 25"
Substrate thickness range: min 12 micron ( 0,5 mil) Up to 250 gr/m²
vipzak2@gmail.com
Unwinder
Rewinder
vipzak2@gmail.com
Клея для полиграфии. (0)
Схемы и инструкции (52)
RYOBI 522 HX (0)
Электросхема RYOBI 522 HX (0)
