KOMORI L 528 + C+ UV
Year: 2003
Aprox: 173 mio imp
Max. Size 520 x720 mm PQC print quality system CMS MONOTORING system Plate cylinder tilt adjustment COCKING Chrome plate cylinders Chrome-plated PQC cylinders S-APC semi-automatic plate changing Automatic ink roller cleaning system Automatic blanket washing device Cardboard printing device up to 0.8 mm UV equipment: Chrome blanket cylinder IST UV drying system 2 UV dryers - on dryer units 1 x installed between 1st and 2nd printing unit 1 x installed between the 5th printing unit and coating unit, each combined with a cooling section 1 UV end dryer in plug-in module technology installed in the extension combined with a cooling section Shadow-reduced gripper system Special UV-resistant inking and dampening rollers made by BÖTTCHER Air conditioning units for cooling sections for sheet cooling for intermediate and final dryers Inter Deck - Special coating of the entire inside of the machine as protection against oxidation UV varnish pump Technotrans combination inking unit cooling system for dampening solution processing and inking unit cooling IRS sword thermometer for stack temp. monitoring KomoriMatic alcohol dampening units with cooling and alcohol dosing system with delta rollers Divided quick-release plate rails Register system KPS 3 in the BACHER system Automatic cylinder positioning system Circumferential and lateral plate cylinder adjustment Roller washing device Gripper height adjustment for transfer cylinder to switch from paper Supersensonic sheet sensor • Gripper modified for PVC printing • Druma modification for PVC printing • Raising the machine by 300 mm • Swing gripper PVC - modified • ISOLOK - anti-vibration pads • ELTEX additional ionization device on the feeder Computer for KMS system • Pressure sprayer Weko T 77 C • Color Matching Light for PQC Control Panel • Hatchet pressure plate punch standing model • Mechanical plate beveling device • Print speed preset • Automatic central lubrication • Reserve rollers per different diameter: 1 reserve ink roller • Reserve dampening rollers per different diameter: 1 reserve dampening roller per printing unit Machine in production in Austria. Available in immediately. Free damages in cylinders or gears.
vipzak2@gmail.com
Year: 2003
Aprox: 173 mio imp
vipzak2@gmail.com
X-RITE iCPlate2 X (0)
iCPlate2 X (0)
