Gallus TCS 250
Year 2016
Impressions 2 mm
Technical Details
Speed: 11.000 T/h
Cylinder circumference: 254mm
Web Width: 265mm
Hotfoil Stamping Speed: 8,000 cycles/h
Max print size width: 265 mm
Min print size width: 130 mm
format length graduation: 0,01 mm
Power Supply
Machine Voltage: 400V
Voltage Peripherals: 230V
Net Frequency: 50hz
Feeding Unit
Web Cleaning
Corona Pretreatment
Trimming and Suction
Substrates
Paper: 80 bis 180 g/m²
Carton: up to 300g/m² at max. 0.3mm
Adhesive Bonds: commercially available
Printing
Offset
UV Offset
Printing Units: 4
Finishing
Coating Units: 1
Rotary Die Cutter Units: 1
Rotary Hotfoil Embossing Unit
Compensating
Web Inspection
Web Inspection type: Powerscope 4000 manual
Drying
Model: Uviterno Coldstar
Water cooled
IR or UV: UV
Run Out
Trimming Knives: 4
Mesh Pulling Monitoring
IR Dryer
Web Storage
Max. Web Diameter: 800mm
Automation and Equipment
Remote Maintenance
Plate Tool
Maintenance Tools
vipzak2@gmail.com
