KOMORI LITHRONE 520
Year: 2003
Approx. 50 mio
Sheet-fed offset press - Printing units: 5
Largest sheet format: 375x520mm
Smallest sheet format: 100x148mm
Largest print format: 360x510mm
Material thickness: 0.04 - 0.4 mm
Panel format: 459x530mm
KOMORI tapes feeder
Electronic, self-adjusting system for detecting double and missing sheets as well as skewed sheets
Electromechanical double sheet sensing
Fine adjustment of the side markers during the run
Central adjustment of the brushes on the feed table
Cylinder Preset
two mooring speeds
Ionized air blast
Fine adjustment of the side marks during the run from the control station (+/- 3mm)
KomoriMatic alcohol dampening units with cooling and alcohol dosing system
New KPC-Komori plate changing system, tool-free and automatic, no bending device required
Circumferential and lateral plate cylinder adjustment.
Roller washing device, automated.
automatic blanket washing device
Possibility of using materials on the transfer cylinders that counteract smearing, e.g. B. TY paper or Superblue-net
Applicator roller can be switched on/off pneumatically
Cleaning scavenger
KPD- Komori Pre and De-inking System
Cylinder cocking skew correction from control panel
Cylinder-oriented register system 425mm
Chrome plate/impression cylinder
Continuous delivery mechanism with stretching system
Speed adjustment for the sheet brakes with suction air
Pre-adjustment of the fans in the delivery for precise depositing of the sheets
Toyo pressure sprayer integrated
Antistatic device
Automatic central lubrication
PQC- Print Quality Control - control center via
Screen
Floppy disk drive for loading and saving Ma
Data transfer from the preliminary stage.
Ink ductor cycle and time from the control desk
Cardboard device up to 0.60 mm substrate
Chrome rubber cylinder
Changing stand for cleaning dungeon
IVT Combi C 191 LC for Komori Lithrone 20
Combi C IR dryer for drying paint and protective coatings :
System works with short-wave IR rays and has an integrated water cooler
Print speed preset
vipzak2@gmail.com
