Komori GL-429 Coater with Dryer LED-UV,
Year 2018
53x75, 4 Colors, Coating Tower Tresu, Extended Delivery
Counter: ca 50 mio impressions
Equipped with:
BandConsole PQC-S Komori (Print Quality Control)
BandWallScreen KID (Komori Info-Service Display)
BandPDC-SG ((Print Density Control)
BandKHS-AI (Advanced Interface) with Self-learning Function
BandAMR (Automatic Make Ready)
BandFAPC (Automatic and semi-Auto Plate Mounting)
BandCocking Register (lateral, vertical & diagonal)
BandAutomatic Washers: Rollers, Blanket & Impressions cylinders
BandPre-connected to CIP3
BandKomorimatic Dampening
BandRefrigeration System Technotrans Alpha-c 120L
BandTechnotrans Alcosmart AZR
BandSuction Tape Feeder
BandUltrasonic Double Sheet Detector
BandAir Side lay and Front lay Detector
BandAutomatic Pile adjustment on Feeder
BandPaper Thickness: 0,06 ~ 0,8 mm
BandInk Temperature Control
BandSkeleton Transfer Cylinder
BandChromed Impression Cylinders
BandExtended Delivery X2
BandStatic Eliminator
BandDryer Spectral-Baldwin LED-UV with LED Cooler 8L
BandCoating Tower Harris & Bruno with "Chambered Doctor Blade" and Anilox roller
BandAutomatic Washer LithoCoat for Chambered Doctor Blade
BandAir cabinet with the machine
BandSpeed 16500 sph
BandMachine Raised 200 mm
BandIncluding: Compressor, Plate Punch, Manuals, Tools and Accessories and Transformer
vipzak2@gmail.com
